Autor Wątek: Apple Car Play - 2019  (Przeczytany 473788 razy)
Offline mr1985
  • Wiadomości: 20
  • Samochód:: Corolla 2019
Odp: Apple Car Play - 2019
« Odpowiedź #1245 dnia: 22 Lutego 2023, 19:49:21 »
Chyba się poddam...
Próbwałem wszystkiego. Znalazłem rozwiązanie error code:1, post użytkownika Rivorian:
https://www.toyotaownersclub.com/forums/topic/195353-retro-fit-apple-carplay-android-auto/page/8/#comments
If the update was unsuccessful and you see a failure message that threatens to replace the radio, remove the pendrive from the radio
Hold the on / off button (volume knob) to reset the device
The device will return to the same screen. Wait for half of the screen to turn green and hold the on / off button again to reset it again and go back to your normal home screen
Open the USB3 flash drive on your computer and delete the phaseup.dat file from it
Insert the flash drive into the car and perform the update again
When you see a blue screen saying success, turn the ignition switch off and on
Go to Settings> General> Software Update
You should be able to see the Audio 1011 version
Click "Model Information" and remember the DCU Part Number
Open the USB3 flash drive on the computer, enter VehicleParameter, DCU and the folder corresponding to the number from the previous step
In the DCU / FactoryID folder, you will find the env_pana.txt file. Open it up
Find the line starting with "VP_PANA_model_ID" and write down the model
Go back to the root directory on the pendrive and delete the file corresponding to your current DCU model, remembering its name
Rename the file with the model name found in the file two steps above to the name of the file you just deleted
Connect the flash drive to the car, wait for the update to complete
Pokombinowałem instalacja przeszła. Ale AA nie mam...
Dalej DCU:17DT1EU-DA002 nie zmieniło się na DCU:17DT1EU-DA30
https://ibb.co/0Jb4cy5
https://ibb.co/kmh5fgd
Nie mam nawigacji wiec USB1 czy USB2 nie startują. Ktoś ma jakieś pomysły?
« Odpowiedź #1246 dnia: 22 Lutego 2023, 19:57:31 »
Widzę, że masz corollę, a w tym modelu z 2019 w ogóle  możesz użyć tych plików by mieć AA?
« Odpowiedź #1247 dnia: 22 Lutego 2023, 20:05:38 »
W tamtym roczniku takich cudów jak AA i CP przecież nie było.
Offline mr1985
  • Wiadomości: 20
« Odpowiedź #1248 dnia: 22 Lutego 2023, 20:15:48 »
Wymieniłem radio, uległo awarii. Rok temu w ASO wgrali mi AA za 300zł jak miałem jeszcze gwarancję. Teraz sam chciałem powalczyć.
Offline lol19pl
  • Wiadomości: 772
  • Samochód:: Cupra Leon ST
« Odpowiedź #1249 dnia: 22 Lutego 2023, 20:20:05 »
Były, po jakimś odblokowaniu/aktualizacji, dziwi mnie co kolega pisze, bo teściowej zrobili za free przy przeglądzie.
Offline apek
  • Wiadomości: 1145
  • Samochód:: Tesla Y
« Odpowiedź #1250 dnia: 22 Lutego 2023, 20:27:20 »
Ale czy przy Corolli nie ma innych plików jak w rav4? Ja w Corolli (2019) nie miałem nawigacji, wgrałem wszystko z jednego usb, zajęło to chyba 40 minut może mniej i przeszło bez problemów. AA się zainstalowało. W ravce już tego robić nie musiałem. Poszukaj plików do Corolli nie do RAV4 linki są na forum w dziale o AA w Corolla TNGA. Gdzieś ok. 51 strony może wcześniej nieco.
https://ts.la/andrzej248745
Offline mr1985
  • Wiadomości: 20
« Odpowiedź #1251 dnia: 22 Lutego 2023, 20:34:44 »
Od niedawna jestem na forum. Nie rozumiem Twoich skrótów.
Możesz rozwinąć ...dziale o AA w Corolla TNGA
Offline apek
  • Wiadomości: 1145
« Odpowiedź #1252 dnia: 22 Lutego 2023, 20:35:54 »
Offline mr1985
  • Wiadomości: 20
« Odpowiedź #1253 dnia: 22 Lutego 2023, 20:46:43 »
Czytałem to juz kilka razy...
W innm wątku ktoś napisał:
Wszystko wskazuje ze toyota przygotowała uniwersalne paczki pod wszytkie rodzaje multimediów dla rav4 i corolla z 2019. Ma to sens bo serwis nie bedzie musiał się zastanawiać co do którego auta wgrać.
Opis powyżej jest z forum (przynajmniej ja taki znalazłem) dla corolli ale z powodzeniem Hiszpanie wgrywali to do rav4.
http://forum.toyotaklub.org.pl/index.php/topic,46275.msg682411.html#msg682411
Offline apek
  • Wiadomości: 1145
« Odpowiedź #1254 dnia: 22 Lutego 2023, 20:53:44 »
Nie wiem, ja to robiłem trzy lata temu gdy pliki można było ściągnąć ze strony Toyoty i nie miałem z niczym problemów. Linków możesz poszukać też u ruskich, kiedyś widziałem, że jest ładnie strona przygotowana.
Offline mr1985
  • Wiadomości: 20
« Odpowiedź #1255 dnia: 22 Lutego 2023, 22:09:52 »
znalazłem coś takiego... identycznie jak ja miał error code:1
Podjechałem do serwisu Toyoty i poprosiłem o zaktualizowanie radia do AA.
Koleś który to robił stanął w tym miejscu na błędzie 001 aż 3 razy. Powiedział że jego instrukcja mówi o miękkim resecie radia i robienie aktualizacji do skutku.
Po miękkim resecie radio zaktualizowało się do wersji  A A 1023 z końcówką DAO30.
Niestety musiałem zapłacić za usługę 300zl ale może to pomoże innym użytkownikom.
Miekki reset??? Może chodzi o to uktyte menu w radiu i INT (reset ustawień).
https://www.youtube.com/watch?v=MjvYVUanTa0
« Odpowiedź #1256 dnia: 22 Lutego 2023, 22:28:04 »
Pakiety skompresowane miały - 12,7GB, 9,15GB i Skrypt 156kB
Skąd jesteś?
Offline mr1985
  • Wiadomości: 20
« Odpowiedź #1257 dnia: 22 Lutego 2023, 22:33:41 »
tak dokładnie tyle zajmowały. Opole
« Odpowiedź #1258 dnia: 22 Lutego 2023, 22:35:31 »
No to nie pomogę, Szczecin. Pliki wypakowane i pen czysty po Fat 32? Na jednym penie może być tylko jedna paczka.
Offline mr1985
  • Wiadomości: 20
« Odpowiedź #1259 dnia: 22 Lutego 2023, 22:52:10 »
Dokładnie ;) uwierz mi nawet zagraniczne fora już czytałem... chyba bez ASO się nie obędzie.
